oznaceni motoru
bajt
Vůz: ,mercedes b170,xc60 d3 my17
oznaceni motoru
Příspěvek od bajt »
hezký den,narazil jsem na toto označení benzínového motoru-B5254T12.prosím vás,znalé,co to je za motor,dával se do aut pro evropu?díky všem.
Nosound89
Vůz: S80II 4,4 AWD
oznaceni motoru
Příspěvek od Nosound89 »
T5 co se dával do všech modelů, viz níže (ale jak zjistit trh nevím)
https://en.wikipedia.org/wiki/Volvo_Modular_engine#B5254T12
B5254T12
The B5254T12 is a 2.5 L (2,497 cc) straight-five. Bore is 83 mm (3.3 in) and stroke is 92.3 mm (3.6 in) with a compression ratio of 9.5:1. It is turbocharged and intercooled with a power output of 254 PS (187 kW; 251 hp) at 5400 rpm with 360 N⋅m (266 lb⋅ft) of torque at 1800–4800 rpm.[205] The TF-80SD and TF-80SC transmissions are available with this engine.[206]
Applications:
2013–2015 Volvo V40 II badged as V40 T5[207]
2013–2015 Volvo V40CC badged as V40CC T5 AWD
2013–2015 Volvo S60 II badged as S60 T5[208]
2013–2015 Volvo V60 badged as V60 T5[92]
2013–2016 Volvo XC60 badged as XC60 T5 AWD[205]
2014–2016 Volvo XC70 II badged as XC70 T5[209] or XC70 T5 AWD[210]
bajt
oznaceni motoru
Příspěvek od bajt »
nosound moc díky,naprosto vyčerpávající :thumbup:
