AUX na HU-650
wtoncek
Vůz: Volvo XC70 D5 136kw 2007
AUX na HU-650
Příspěvek od wtoncek »
Ahoj, mam ve volvu XC70 2007 radio HU-650 a v loketní opěrce je vstup 3.5 jack, nevíte někdo jak se přepíná na radiu aby to hrálo třeba z mobilu?
shaman
Vůz: Peugeot
AUX na HU-650
Příspěvek od shaman »
Quote Originally Posted by new daddy View Post
I came across this table (http://vccs.volvocars.se/Accessories...ent/VCC-249527), which claims that HU-650 has an AUX input. I don't see any input on the front panel. If it's hiding somewhere in the back, how do you change the input to Aux without any button assigned to Aux in the front?
If the input is hiding somewhere in the back, is it possible that the Motorola bluetooth receiver that my dealer installed for me is already occupying the input?
I'm trying to find a way to play my iPod through the car speaker without resorting to a lousy FM transmitter and all but gave up on HU-650 and was about to upgrade the radio. If HU-650 harbors an AUX port somewhere, maybe I don't have to go down a more expensive upgrade route.
The AUX input is located inside of the center console. If you don't have it there that means your car is not equiped with one and you will need to go iMIV or similar route.
To select AUX input you rotate the Source knob.
http://www.volvoxc.com/forums/showthread.php?17566-Where-is-the-AUX-input-in-HU-650
postapo.cz
wtoncek
AUX na HU-650
Díky!! Vyřešeno :Yahoo!:
hefaistos
Vůz: xc90 2008 3.2
AUX na HU-650
Příspěvek od hefaistos »
Jeste dej vedet jakou to ma kvalitu zvuku, pripojeni cez aux je jako radio z roku 1950 :lol:
wtoncek
AUX na HU-650
No je to o dost horší než z cd...
AUX na HU-650
Mřkni na yatour
