480 turbo - uprava CEM - higher boost
Malé, ale Volvo...
Příspěvků ve vlákně: 2
#1 480 turbo - uprava CEM - higher boost
Příspěvek od berzerker »
skusal to niekto? 440 asi takuto elektroniku nema....
Kód: Vybrat vše
[color=#00FF00]The modified CEM
Let me tell you what I did to my CEM. If you open the CEM box (the one under the centreconsol) you'll find two resistors, one of them named R206 (is a double, same as R207) and the other R207. Unsolder both of them. Then solder on two cables where the R207 was and and jack them onto a potentio-meter. Then put the box back together and take the car for a ride. Start with potentiometer in the bottom, put your car in third gear, foot on the brakes and pedal to the metal (must be over 4500 rpm). Watch the pressure gauge and take note. Then turn up the potentiometre and do the same thing over and over again until you find the presure at a level you prefer, I do not recomend that you boost it up so it goes in to the red field on the original pressure gauge (~0.8 Bar), because the fuel wont be enough, it can take more, but I wont take any responsability with what you do to your cars. When youre done and satisfied with the pressure simply solder off the potentiometre and measure the resistance in the potentiometre and buy a resistance that has the corresponding value, costs almost nothing. Solder in this new resistor in your box (where the R207 was) and put it back together. Enjoy!
If you want to you can make a switch (I did so) so you can drive with the standard resistance and standard boost if you want to. I've got one stage (standard) 0.5 Bars, and switched ~+0.8Bars.
The car will respond very well in the higher revs (4500 and up). The MBC makes the car go fast at ~3000 rpms. I've combined these two mods so the car goes fast from 3000rpms and up. So far my car has managed about 1Bar with no problem, but that's just for 'special occasions'. ;)
Warning, the original booststop at 0.9 Bars doesn't work when you've done this modification! So if you turn up your MBC the turbo will run until it blows if you don't do it with moderation and common sense...
Pics and instructions in swedish made by Peter, the 'inventor' of this :
http://www.480center.com/servlet/user?action=view_article&id=332[/color]
Příspěvků ve vlákně: 1
Vůz: Nissan E.110/35
#2 480 turbo - uprava CEM - higher boost
Příspěvek od CouDy »
To je jako zvýšení plnícího tlaku turba?? jestli jsem to teda správně pochopil pomocí CEM neboli oblbnutí tí el, potvory co mi sedí u motoru a ucucává vzduch z turba a koštuje kolik má síly?? :lol:
1.480 - .........
2.480 - B18FT (regál)
3.V40 - B4204T
4.TMracing EN450Fes 05´
S3->Nissan Cabstar - BD30Ti
Vůz: S60, 2.4T
#3 480 turbo - uprava CEM - higher boost
Příspěvek od lucki »
zrejme hej. sportovec si spravil prepinac medzi dvoma rezimami, klasik a ,,sport,, s vyssim tlakom. neviem ci by som do takehoto niecoho isiel. to radsej poriadnu generalku motoru a turba.
440 turbo, 1.7 '89, modra
Kontaktovat uživatele:
#4 480 turbo - uprava CEM - higher boost
Příspěvek od Zbynek »
CouDy píše:To je jako zvýšení plnícího tlaku turba?? jestli jsem to teda správně pochopil pomocí CEM neboli oblbnutí tí el, potvory co mi sedí u motoru a ucucává vzduch z turba a koštuje kolik má síly?? :lol:
to neni zviseni tlaku to nejde to je dane od vyrobce pouze casovani ze to bude mit rychlejsi zaber turba, ze tlak bude driv nez byl takze se zda ze auto jede lepe ale pozor na predcasne nacasovani protoze v nizkych otackach se to muze potkat.
Mercedes E320 lorin.Volvo V40 1.6 16V
#5 480 turbo - uprava CEM - higher boost
podla toho co tam pise to zvysenie tlaku turba je.
Skusa tam za jazdy pomocou potenciometra pridavat odpor na volakom rezistore a to zvysuje plniaci tlak, ked sa dosiahne ziadany tlak , tak sa tam zamontuje odpor s danou hodnotou...aspon takto tomu rozumiem ja..a da sa k tomu prirobit aj prepinac medzi normal a zvysenym tlakom.
Vůz: Volvo S60 2,5T AWD BSR
#6 480 turbo - uprava CEM - higher boost
Příspěvek od Stalin »
Zbynek píše:
Jestli dobře koukam tak to turbo tlači 0,5baru????
#7 480 turbo - uprava CEM - higher boost
Příspěvek od nismo.power »
bezvadný, to sem taky moh vědět dřív než sem koupil MBC :)) jinak samozřejmě jde o oblbování originálního MBC odporem ......... udělat plnící tlak dřív je naprostá volovina jak tu někdo psal, prostě nejde , jde ale při použití jinýho turba ;-) při origuje to daný objemem vs. otáčky podle toho se roztáčí turbo a tim nikdo nehne leda by mu fiknul downpipe 20čísel za turbmem pak by nemělo odpor a šlo by lehce dřív do otáček :)
jinak super nápad ale nejde ten link co je vespod :(
je to vlastně takový EBC za cenu jednoho potenciometru :) stejně plánuju ale ten pojebanej ventil co tam je origo dát pryč a dám si tam svuj MBC..... tenhle elektronickej stojí za **** :)
Cadillac Seville STS 98´
Cadillac Seville STS 00´
Volvo 480 1,7 Turbo
R5GTE
Odpovědět
  • Podobná témata
    Odpovědi
    Zobrazení
    Poslední příspěvek
Zpět na „300 / 400“
